Need help: HDD failing
TehQuick
Well, it's been a while since an HDD failed on me and here it is again. I was getting random errors for a while now, system hanging in 3d, not resuming properly, BSODs related to RAM, and hangs on boot. Well, it seems that a certain drive is causing that (removing it removed my latest issues with hang on boot - system doesn't boot with suspect drive and OS drive but boots with suspect alone, and boots fine with OS and all other drives in my system, go figure).
What can I do to recover data before this drive goes completely dead (if it's not already, it boots alone in the system but I dunno if it's accessible)? Finally, how can I make sure that this is drive alone and not another one failing?
EDIT: found WD diagnostics, ran them under dos - no errors. Ran quick diagnostics with Windows Seagate tools on other drives, seem to check out
I'd suggest purchasing Spinrite. It's expensive (around $90) but it's by far the best software investment I've ever made. Also, if it doesn't work, you can always return it for a refund. As a PC tech, I've had so much success with it that I carry it around on a bootable USB stick at all times!
Good luck!
thanks for the suggestion, I'll try that. The weird thing that the drive passes tests in DOS alone but still hangs the system at boot if I plug my OS drive in. So I'm at a loss as to how to backup the drive. I guess I'll try this program instead of windows copy :D
