need help from those with 6800's
i have a Nvidia geforce 6800 with latest drivers, and im having trouble setting up 2 monitors....
the only modes i seem to be able to set up are Clone (where both are the same stuff showing) and horizontal span where it stretches across both monitors....
on my old radeon there was a way where it didnt clone but it didnt strech everything, effectively you had twice the desktop space, but when you maximized something it only maximized to the size of one monitor, in the horizontal span mode if i maximize something it spans across both monitors, and you can imagine that is quite anoying...
anyone know how to get it to the mode i want? let me know if i need to give a better description
thanks for all help :)
There is another option that you can choose to install.
It should be in the Nvidia control panel I think it is called Dual View.
