Need Help for Samsung 46" DLP
Escher
I've got the HLS4666W Samsung 46" DLP TV. It worked fine for the longest time, but started acting funny recently. What happens is that a couple of seconds after the TV is turned on the picture comes up, the screen will flash off/on real quick and reset all settings on the TV. All customizations for color, source labels, etc are completely lost forcing me to have to set them all back up again.
Anyone know what could be causing this?
Nevermind, got it fixed. Found a site that showed me how to access the "secret" service menu. Though they were speaking of how to fix some "lamp hour" setting, I found a "User Reset" option and got brave and used it. Seems that reset my whole TV to factory settings and now it works!
For those that care, do the following with your Samsung DLP:
1) Turn if off
2) In sequential order (i.e. not at the same time), press Mute, 1, 8, 2 and then the power button.
3) TV should turn on with the service menu displayed.
Lots of goodies in that menu that I wish I knew what they meant.
