Need help for dedicated streaming rig
Douglas
I'm noob when it comes to mostly everything about pc building If you guys could help me out it would be amazing.
The rig will mostly be for streaming games such a pubg at high settings or any game at high settings.
1) What will you be doing with this PC? Streaming!
1200$ Shipping is not Included.
Maryland.
4) What exact parts do you need for that budget? CPU, RAM, MOBO, SSD, GPU, PSU, CASE, Cooling for CPU? I dont know If I'm missing anything feel free to add something if I missed it
5) If reusing any parts, what parts will you be reusing? None
6) Will you be overclocking?
Maybe
24'
Pretty soon
9) What features do you need in a motherboard? I have no Idea what this means
10) Do you already have a legit and reusable/transferable Yes Windows 64
Did you want to use hardware acceleration to create your streams, or do you just want to "add more cores?" One is cheap and easy, but suffers from a little less quality. The other is more expensive.
Well, to get eight cores from AMD, I'll have to bump your graphics cards down to a GTX 1060 6gb (it's more than capable of 1080p 60fps gaming). Or you can bump your budget up by $200, and get the 1070 ti?
I think 1060 would be fine since all this pc would be doing is just for streaming not really gaming. I should've explained more sorry. I'd Like to run just a dedicated streaming rig
Oh, then processor first :D
PCPartPicker part list / Price breakdown by merchant
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor ($309.99 @ SuperBiiz)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler ($34.89 @ OutletPC)
Motherboard: ASRock - X470 Master SLI/AC ATX AM4 Motherboard ($129.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($179.99 @ Newegg)
Storage: Western Digital - Blue 500GB M.2-2280 Solid State Drive ($119.14 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card ($299.89 @ OutletPC)
Case: NZXT - S340 Elite (Black) ATX Mid Tower Case ($59.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($54.99 @ Newegg)
Total: $1188.87
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2018-04-27 19:00 EDT-0400
This should give you the most powerful streaming processor without going Threadripper/SkylakeX. You can also step down to a GT 1030 if you just want a video card, and not a gaming-capable system. That will save you $200, and still supports dual 4k monitors.
https://www.newegg.com/Product/Prod...14137140&cm_re=gt_1030-_-14-137-140-_-Product
Oh damn I appreciate all the effort that you put in this even providing the prices thanks a lot
I'm a little confused. Do you want to run a dual PC setup, 1 for gaming and 1 for streaming? Or do you want to build a single PC to do both?
1 for streaming 1 for gaming
What are the spec of your gaming PC?
Streaming PC you just need a good capture card, audio mixer (you can use splitters but a mixer is supposed to be better), and a 4 core cpu. Small SSD for OS and a HDD. Video card does nothing so just run integrated if you can or get something cheap. A friend set one up recent and just got a Dell with a new i3, 8gb, SSD/HDD and it has been working great.
