Need help for a $200 or less card
Klade
Hello
I'm a few weeks away from building a new gaming machine. My total cost for the box is set at $1000. Out of that I'm allowing $200 to be spent on the video card. So now the question is, what to get?
The card will need to be pci-e 16x and I have no plans of running SLI/crossfire. This card has to hold me for a while so I want the best bang I can get in that price range. Any suggestions here would be greatly appreciated.
Also is it just me, or has newegg prices become more expensive compared to other websites, as opposed to the same ratios from about a year ago?
that's after rebates and crap....
add $20 mroe bucks for the X1900XT 256mb.
I would consider a X1900xt except that I can't find one for less then say $240 which is more then I want to spend.
So the 7900gs is better then ati offerings then?
ATi doesnt offer much good below the $200 mark, and the 7900GS would be fine for most things i guess, but really...if you can spend the extra $40 on a card, the 256mb version of the X1900XT is the golden apple.
seriosuly, let's put it this way, the X1900XT is on par and sometimes surpassing the 7900GTX ............... enough said, pay the extra $40.
no reason to roll eyes... that thing is open boxed and oem.
IMO for a gaming box you should be spending more money on the video card than anything else. Like 40% of your budget should be video card :D
I'll hazard a guess that you are wasting too much money on CPU power and not enough on video card power.
Ok you guys talked me into it. I really didn't want to spend more then $200 but it seems the extra 40 will really make a difference so I'll shoot for the x1900xt.
What are you gaming in?
At 1280x1024 in Oblivion I have everything on maximum (HDR no AA) and driver overide UQ and 8x AS filtering...
I get frame rates that are very-very playable (I've never seen anything lower than 32)
That, of course, is with a card slower than the 7800GS.
