I need some parts for a case mod that I'm doing but I don't really know where to order it from.
What I need is a bunch of male to female cables for usb, ps2, firewire, vga, and audio jacks. They need to be shorter than 6 inches or hell if I can find the connectors and bare cable I can make them myself whatever length I need.
To clarify the case mod involves a case inside a case(sort of) and I need to route the inside connectors to the outside of the bigger case's io panel and pci slots.
I would perfer to make my own cables because that way I could pick which end I want because for instance the vga connector on a video card is a female hd15 and i would need a male hd15 to female hd15. Now the female hd15 would have to be mounted to a pci slot cover to make it look like there's a agp video card there.
I hope there isn't too much confusion on what I need. If so I can draw up a diagram later.
Thanks,
Thanks,
