Need help finding SFF case with handle
CyCo_SoMaTiC
Ok I am getting ready to do a new build. I want the following: small form factor case(matx), a handle built into the case, with the ability to fit a ATX power supply in it. I have seen the older Apevia x-qpack, and to be honest that would be perfect if they still made it. The current ones look very flimsy, with the handle built into the front. I found a Thermaltake version but it has also been discontinued. I just am sick of big cases and want to be able to easily move my new rig for LAN usage.
There is the SG04 and if you want something a bit bigger, cools better and holds more, but still portable I'd say look at the NZXT Vulcan. Also if you are dead set on small cube like cases you can always buy a harness like the ones Geargrip make or get the Sugo bag. You do have some options.
They must have done it today. No pic image of it posted yet. Its going to be interesting to see how well this case works out. I'm very curious how well it cools for those using it for a gaming rig. I'm not a fan of cases with single intake fan only.
I have built computers using the Vulcan case, and I also recommend it.
The best computer case I've ever built with. Most of them have been cheaper stuff, but this was pretty decent for sure
