tankman1989
- Aug 21, 2009
Greetings,
I have two situations both involving an Abit Mobo. One is a IP35-E and the other is IP35-Pro. I need a new mobo for the IP35-E as the CPU receptacle has been damaged (two pins pushed under.
The IP35-Pro has a number of issues but mainly it will not allow for keyboard entry during boot times except for when the CPU, RAM and HD's are being detected on the very first screen. Here I can hit Delete to enter BIOS and make changes. Other than that I am stuch with the default first selection for anything as the system boots such as when Windows doesn't shut down properly the user is given the option to select "boot safe mode", "safe mode w/networking", "Last known good configuration" etc. and then a 30 sec timer counts down and I can do nothing but sit and watch. I'm unable to select any of the options. I don't know if there is something that can be changed in BIOS to fix this or not?
So, if I need ot get new mobo's I have trouble figuring out what new mobo's will work, or should I just but new RAM, CPU and Mobo? I currently have 8GB PC6400 DDR2 on my IP35pro and a Q6600 2.6Ghz. The other machine has 3GB DDR2 PC6400 and a E6850 (??? )CPU.
So, what would you do, all new Mobo, RAM and CPU or is is possible to just buy a replacement mobo that will work with the existing hardware. Any ideas here?
I rally appreciate your help.
