Need help finding GPU WB
well I got back my RMA from BFG and instead of another 8800GT they sent me a GTX260 maxcore 55nm.
What's a good wb for it? I'm a bit worried because on PPC the EK wb for the gtx260 says it is not compatible with the new vs of the PCB and I'm sure I have a new one. any ideas or which block I should get?
First thing you need to do is determine which PCB revision you have, or you'll be eating waterblocks in a hurry.
