Need help finding connectors
spidy
I'm hoping someone can help me with this. I'm building a computer case from scratch. However, I'm having a hard time finding connectors for the motherboard to hook Power switch, power led, reset button, etc . Does anyone know where I could buy the proper connectors? Thanks all. :D
Umm there should be wires dangling from the case... I dont think you can buy those wires and hook them up to the case.
The guys over at the case modding forums probably have some better answers for you. There definitely has to be someone selling these things, but I have no answers for you. They probably aren't very hard to make though. All the power switch does is short 2 pins to power the system on, same with reset. And the LED ones are just LEDs with wires as extensions... But yeah, probably not worth the trouble. GL, though.
Thanks everyone for the quick reply. Anarchonixx, that's what I've been looking for. Although the price is steep and I won't be needed everything, but that might have to do for me now, thanks. I found a lot of connectors at www.allelectronics.com, thanks Ignad, I've been able to find servo connectors but everyone only have 3pin :( . I need variety like 2pin, 3pin, and 4pin. So for now the search countinues unless I want to shell out some $$ and scrap most of it.
After hours of searching through www.mouser.com very large catalog :eek: I found what I was looking for. Thanks for everyones responce.
For anyone else looking for those connector you can find them on page 848 in there catalog.
Thanks for that spidy! In posting what you found in your search, you have probably saved me and others hours of searching. I will be custom building my own case soon too, and that info will come in handy.
