Need help finding a reservoir
bullseye4u
Hello, I need help finding a reservoir you know the reservoirs that danger den makes
http://www.dangerden.com/store/home.php?cat=28 rounded where you can fill it up in the top just buy opening the fillport at the top. Well I wonder is there something similar except its not round but a square? Since my case could fit in something square but not round. I am sure some company could do that or has them jsut cant find it any where.
yes like this one
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=318&products_id=3615
But I want it to be up top but the hole is to big on that one to fit a danger den fillport
Your pronoun usage is ambiguous; I'm not sure what you are saying.
So you want something like the Swiftech micro-res, but you want a fillport? If that's the case, it's an optional $3.00 upcharge at the performance-pcs link you posted. If you got the optional G1/4 threading, you can either put a fillport into the reservoir, or you can put a barb into the top of the reservoir, and run a tube up to a fillport on top of your case.
AFAIK, performance-pcs is the only place to order a micro-res with the G1/4 mod.
edit: I guess I misunderstood some posts about this mod that I saw a while ago. It doesn't seem like you can just put a fillport directly into the G1/4 threaded hole - just a barb - or anything else that's G1/4 threaded. I don't know what threads are on a DD fillport, as I don't have one myself. I prefer the bitchin' industrial look and low price ($2.50) of the industrial brass fittings at the hardware store for my fillport usage...
what is a G1/4 ?
the dangerden fillport they make are 1/2 or 3/8 fitting where I can get a 1/4?
what is a G1/4 ?
G 1/4= pretty standard thread size for watercooling, i.e. you can screw a g1/4 barb into the res fill port and run it to a dangerden (or whatever) fill port.
Make sure you select the G1/4 threading option for the reservoir.
Have fun building your loop. Good luck.
Fillport
Fitting
Res
Took about 10 seconds.
alright so I just buy everything 3/8, so i buy the
http://www.dangerden.com/store/product.php?productid=210&cat=34&page=1 this 3/8 than put the fillport inside that correct?
that is this one
http://www.dangerden.com/store/product.php?productid=244&cat=35&page=1
also what fitting style high flow? or doesnt matter and what is poly T?
Also i am thinking using this pump http://www.dangerden.com/store/product.php?productid=142&cat=26&page=1
can anyone tell me how you turn it turns on does it connect to the power supplier 4 pin?
