Need help finding a Projector for Church
hellomynameis
I have been given the job of finding a projector for the church to use in the main service. I will want to mount it on the ceiling which is about 25-30 feet up and will be like 10-15 feet from the screen. So what I need to know is what spec's on the projector i should be looking at?
God knows :confused:
terrible joke :D
Its not that hard to do. First go to projectorcentral.com, use the selection tool to find a candidate projector (connections, features, etc). You will definitely need 3000+ lumens depending on how bright your interior lighting is, though thats the transition between budget projectors and expensive ones. If you are not constrained by a budget go for at least 5000+ lumens. Use the calculator they have there to find the right lens - choose fixed lens if possible, though zoom will give you some leeway in mounting it.
