Need help finding a case
50Cal
So i currently have an NZXT phantom and im tired of having to buy nzxt brand fans for this damn case.
Im looking for something That will lay down like the CM HAF XB EVO (http://www.newegg.com/Product/Product.aspx?Item=N82E16811119265) or the Corsair Carbide 540 (turning it sideways http://www.newegg.com/Product/Produ...&cm_re=carbide_air_540-_-11-139-022-_-Product ) but i really want to fit two triple 360 rads in a push/pull config. The Carbide can fit a single triple 360 rad but the top will only fit a double.
So it needs to be "Box-like" and can fit two triple 360 rads in push/pull without a super monstrous footprint. Any ideas?
EDIT: Something like the Thermaltake X9 but without the 25 inch depth footprint.
Bah. Just do yourself the favor and get the X9. Yeah, you'd swear you bought a dishwasher. But that space is put to good use.
If you don't need QUITE that much space, and can go mATX with your board, go for the X2. It'll fit two 360's in the top. It can also take a 360 in the front or on the bottom.
