Need Help Finding 3x3.5mm Extension Cable
TechSoldier
Looking to relocate my computer to the other side of my desk. The whole purpose is to eliminate a rats nest of cables. In order to do so I need to extend my logitech 5.1 3.5mm jacks and I'm having troubles finding an extension that has 3x3.5mm jacks. Sure I could buy 3 single 3.5mm jack extensions but I'm wondering if there is an extension that has 3 all together.
Anyone?
In all sincerity, buy yourself three long cables and zip tie them together. Less clutter. If you find a used cable, it may break. If you find an original Logitech one, it would probably cost more than three good ones from a local store or monoprice.
Thanks guys. I'm OCD when it comes to clutter so I might just end up doing this as I cant find these anywhere. There is a good chance I'll sleeve them together...lol.
