Need help figuring out if new mobo is doa
I bought an open box MSI P6N Platinum from newegg. The box had everything in it and nothing looks wrong with it, but I can't get the system to run. When I power it up it beeps twice, shows the MSI logo screen, then seemingly tries to boot up, then the screen displays the no signal box, then it starts over. It does this over and over.
I thought it might be the memory, so I went out and bought different memory and tried it out, but it does the same thing. I checked all the connections and everything seems fine. If it is the mobo, I need to return it asap or I forfeit my chance to get a refund (15 days).
Full system is as follows:
MSI P6N Platinum mobo
Corsair 550vx psu
q6600 cpu
MSI NX8800gt gpu
2x PATA Hard Drives
1x PATA cd/dvd drive
gskill 2gb single channel 800mhz DDR2
If you're nearing the end, get an RMA # before your 15 days is up.
/*------------- <cut n paste> -------------*/
If you have both the 20/24 pin main ATX connector plugged in, AND the 4-Pin ATX12V P4 CPU connector plugged in, then the board should boot fine.
You could test the PSU. Jump start it (on the main atx connector, short the green wire with any black wire, using a paperclip), and see if it stays on. If not, then it might be a faulty PSU. If it works then its most likely ok to proceed.
Setup everything outside of the case, with the mobo on top of its cardboard box. Plug in only the essentials:
- PSU (namely: main 20/24-pin ATX connector and 4-pin ATX12V P4 CPU Connector)
- CPU w/ HSF
- Single stick of ram
- Videocard if there is no onboard video
- Monitor
- Keyboard
- System speaker/buzzer
* Use a screwdriver if your board doesnt have an onboard power switch. Jump the two power switch leads to turn the power on.
If it won't post, try different RAM slots. If it still won't post, pull out the ram (so no ram in the system) and listen for error beeps. If none, pull the vidcard and listen for error beeps. If none, re-seat the CPU/HSF and try again. Report back with results if you're still having issues.
/*------------- </cut n paste> -------------*/
I set up the motherboard on the box outside of the case and turned it on, and it did the same thing. I tried removing the RAM and when I turned it on it did a long beep and paused, and then kept repeating that.
I also put a paper clip from the green wire to the black wire and the fan in the PSU started spinning up, but stops immediately when I remove the paper clip.
I have 6 days to determine if it is the motherboard or something else causing the system to fail and I don't really know what I am doing. Is it possible my XP install got corrupted somehow? I need to resolve this asap, otherwise I am just going to have to return the board, buy another, and hope that it was the culprit.
If I get an RMA number, can I take more time to return it?
I got this error code, and I googled it to find two threads on the whole damn internet, to which no one had replied with anything useful. I need help and I need it fast. If I send this board back I forfeit 20 dollars on restock fee and shipping, and if it isn't the cause of the problem then that will be a huge waste of time and money. The error code is as follows:
*** STOP: 0x0000007B (0xBA4CB528, 0xC0000034, 0x00000000, 0x00000000)
Once you get an RMA number, its good for 14 days -- so they have to get the return within 14 days. Get the number while you still can, then keep troubleshooting.
When you say you bought an "oem" P6N, do you mean "open box"? If so, then it could very well be the board.
The cut & paste I posted above was to get your system to POST. It now looks like you've already POSTed and are trying to get into windows, is that correct? If so, it looks like your HDD is the culprit, according to the Stop Error code you posted. It could also be the HDD cable or the HDD Controller (on the motherboard). Which drive are you booting off of? Can you try another HDD? You could also run some diagnostics on the boot drive -- get the software off of the drive manufacturer's website.
Ok, I do mean open box. I didn't know what oem meant. Good thing I am fine with looking foolish.
I don't really know what posting means or how to tell if it has. I do have a 4-led interface installed that came with the mobo that displays light codes using green/red lights. It goes through a series and stops on all green, which means the OS is starting up. After this it restarts and goes through it all again.
The hard drives were both part of my old system and worked fine. I even used the old cables, so those should be fine. I didn't smash, drop, or even bump the drives during installation, so I would assume that that means it's the motherboard's problem. I have booted from both my hdd's and when I use the one with windows XP installed it just keeps cycling through the boot process. When I use the one without windows installed it says it can't detect an OS (or something like that) and goes no further. I have booted from my win XP cd and have done chkdsk and it says the windows installed hdd is fine.
The GPU and CPU are both new as well, is it possible that they are the culprit?
POST means Power-On Self-Test. So, if its began loading the OS, its finished POSTing. Since you're using your old drives, its most likely a windows issue. Boot from the XP disc and proceed to install as you normally would with a fresh install. Choose the same partition the old OS was installed onto, and setup will detect the old installation. Once detected, it should give you the option to repair the current installation by pressing R.
It gave me a bunch of error messages when Windows was installing, but it seems to have worked because it booted up to my desktop. Thanks very much for the help.
