Feb 29, 2008 #1 M MaXXimus Limp Gawd Joined Feb 8, 2008 Messages 312 Trying to order all my parts right now and Im stuck on what fans to get, this is what I need: 6 of these fans will be needed for the PA120.3 and want them all CLEAR led blue. 11x120mm 2x80mm for case
Feb 29, 2008 #2 Y Yuk Weaksauce Joined Jan 23, 2007 Messages 121 Without knowing how load you want your pc there are these. http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=2433 http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=2209
Feb 29, 2008 #3 M MrDude010 Weaksauce Joined Dec 1, 2006 Messages 93 other options http://www.petrastechshop.com/12yalod1cafa.html http://www.petrastechshop.com/12yalod1cafa1.html I like yates, Im using the 47 cfm fans for my rads and theyre suprisingly quiet
Feb 29, 2008 #4 T The Gonz [H]ard|Gawd Joined Jun 24, 2004 Messages 1,131 MaXXimus said: want them all CLEAR led blue. Click to expand... YLs are good fans but useless for his needs.
Feb 29, 2008 #5 A Arcygenical Fully [H] Joined Jun 10, 2005 Messages 25,066 The Gonz said: YLs are good fans but useless for his needs. Click to expand... I think he meant to link to the LED blue yates. http://www.jab-tech.com/YATE-LOON-1...B-UV-Blue-Frame-with-4-Blue-leds-pr-3773.html
Feb 29, 2008 #6 B Big Lar Limp Gawd Joined Mar 21, 2004 Messages 240 I buy fans from svc.com maybe take a look there... Larry
