Need help fast... Celeron d ..compatible with this board?
Dude, it says it in the description that it supports Celeron D's...
Yes, it will work fine. If you can, get an E0 stepping, it is newer than the D1 and will overclock better if you ever try to.
ok first time dealing with intel...all the different cores got to me.
Thanks again!
I have a Celeron D on an Abit IS7 which uses the i865, same as that board. Mine works fine.
