Need help fast! Bluescreens galore!
Tengis
Ive been getting bluescreens that dump my physical memory ALL THE TIME. It says this is the cuplrit.
ati2dvag.dll
My system is:
abit nf7s 2.0
Athlon 3200+ @ 2.39 414fsb
Kingston HyperX Pc3200
ATI Radeon 9000pro 128mb
Catalyst 3.10
That problem appears to be with ATI drivers but you already have 3.10 so I guess you can't really update them. You could try reinstalling and see if that helps. You may also want to use the default windows XP ATI drivers and see if the problem goes away. That would not be a permanent fix but it would give us an idea on where to go from here. Does this happen during normal windows operation, gaming, certain applications, etc. ?
