I dont want acid on it and im not selling it has windows installed twice and its taking up all my memory so I figure ill just go a head and wipe the whole thing
Pop in your Windows XP CD, boot from the disc, when the option comes up, choose to install Windows, and then remove the partition(s) that it finds. Then install. It'll automatically partiton the drive (into 1 partition) and format the disc before installation begins.
Nothing to buy, nothing to install, not to do before the installation. Everything you need is on the Windows XP CD.
Download DBAN (CDR/CDRW version.) and burn it to a cdrw, then boot your computer with it and wipe your hard disk, about the boot disk failure, make sure you select the proper order in computer bios
Is the bios set up to boot from cd first? Go to the bios during bootup (press DEL or F1 it will say somewhere on the screen , it varies) go to boot menu and make the cd drive the first boot device.
