dimastopel
- Mar 28, 2012
Hello guys,
I would appreciate your help designing my home NAS system. I am mostly in doubt regarding the case but would also appreciate help with other parts.
Please find the answers to the sticky questions below. Most important things for me are: limited space (dimensions are below). Place for (exactly) two 3.5" HDDs. Passive cooling.
THANKS A LOT!
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Overclocking, Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
- Storage
- Dropbox sync
- Torrent daemon (probably transmission-daemon)
- SSH server
etc.,
Non CPU / RAM intensive stuff
2. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
The budget is flexible (several hundreds of dollars)
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
I live in Israel but can purchase stuff from US if needed (I have friends that can mail those to me). Of course I'd prefer parts that are sold locally.
4. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
SFF case + power supply -> the part I need most help with.
CPU
Board
RAM
Cooling parts
5. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
I already have 2 3.5" HDD (WD15EADS - WD green 1.5 TB). I want to reuse those.
6. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
Required: 1 GB/s Ethernet
Required: passive cooling for CPU
Required: at least two SATA HDD connectors.
Wanted: as low powered as possible
RAID is not required.
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
Not important. Just a simple VGA / DVI output.
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
YES: 30cm (width) x 20cm (height) x 50cm (depth)
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I prefer not to do any case modifications.
10. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
It needs to be quiet. It is placed in the living room and should work constantly.
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
Not need to be mobile.
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
I want to use debian.
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
In a couple of weeks / months.
THANKS A LOT!
- Storage
- Dropbox sync
- SSH server
etc.,
CPU
Board
RAM
Cooling parts
