Ok, I've been staring at these two pieces of Carbon Fiber for the past week and I can't seem to come up with a design. So, here's where you all come into play.
This is what I have to work with:
And here are the fans I need to cover.
The two 120mm blowholes.
The side fans.
I'm stumped because I only have these two pieces of carbon fiber so if I screw them up, the project is scrapped. So, I'm looking for something simple and easy to do. But I just don't want a cirlcle cut into them with the mesh. I'd like at least some simple little design that would be easy to make using a Dremel and a drill.
Post up your ideas and designs. Later when I get home from work I'll post up some of my designs and we'll pick which one would work best.
The side fans.
