maxbennett
- Oct 3, 2009
Gaming with nvidia 3d vision, web browsing, music, and maybe Photoshop down the line if I ever pick it up.
$500 as I just need a few pieces, not complete package.
3) Where do you live?
San Diego, California.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, Motherboard, and maybe RAM depending on what mobo I purchase.
Monitor, kb+mouse, case, speakers, evga gts 250 1Gb, and 550 watt power supply. Not sure what bramd my PS is but I am confident that it will get the job done for the time being.
6) Will you be overclocking?
I will keep my options open.
I have the Samsung 2233rz for 3d vision- 1680x1050
Would like the main parts by the end of this year.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I need room for a wifi card(pci) and sound card(pcie) plus I want the option for SLI down the road.
10) Do you already have a legit and reusable/transferable OS key/license?
I will be buying Windows 7 in the coming months and will be installing it on a clean WD6401AALS.
Hey guys! 1st day on the [H]ardforum; long time reader, 1st time posting. I am stuck in a pickle trying to decide to upgrade to the q9550 or the i5 750. My current motherboard is the Intel dp35dp and is running the Intel C2D e4500(?) 2.2ghz. Going the 775 route would allow me to plug in the q9550 right away and upgrade my motherboard later. Since, I will be using nvidia 3d vision, I will need as many fps as I can. Benchmarks have shown that the i5 is up to par with the i7, which defitnely outperfomred the C2D series. So, is the i5 worth it to me? Thanks in advance!
