Need help deciding on a MB for my E6700
Duo Joe
Im getting ready to build a new system based on an E6700. Im into first person shooters. I'll be getting a 7950GT and then when the D10 boards come out I'll be upgrading to that. I cant decide on a motherboard for this system. Im trying to narrow it to an Intel D975XBX or the Asus P5N32SLI Premium that just came out. Can you guys help me here?
Get the Intel. nVidias chipset is bad at overclocking (not sure about the P5N32SLI though since it's based on the nForce4 and not the nForce5). If you don't plan on o/c then coss a toin.
Im not into over clocking. I dont think I'll need SLI as Im pretty happy gameing at 1600x1200. I appreciate the help. I recently heard that that Asus 590 chipset board was out and I was wondering about it.
Honestly, if you're not into overclocking, get an Intel board. They are as stable as it ever gets.
Thank you. Do you have an opinion between the 965 and 975 series? I was going to go 975, but Ive read people are leaning both ways.
Asus P5W-DH is nice as well. And it has quite a few extras going for it ...
Sure it is nice....but also double as expensive as an entry level intel i965 board.....
I dont mean to sound like putz, but I dont care how much it cost. I want quality, speed, stability etc etc etc. I figure if I build a Core 6700 with a raptor X, some fast ram and a 7950 series card I wont need to OC it.
well if your not into overclocking and want to save some $$$ there are lots of alternatives that can do what you want --you don't have to spend $250+ for a 975xbx or asus esp since you don't want to OC or want sli or crossfire. anything from a 945p or 965p should be able to do the job nicely .
since money is no object--and overclocking is off the table (although modded the 975xbx can overclock quite a bit )
i would say go intel 975xbx because one day you might find a need for that third pci-16x and it's a very well made mb --i have built a few of them . the only gripe i've had is some people don't think the onboard sound is that great.i haven't noticed that but i haven't played games on the intel box either-.
the on board sound on my el-chepo overclocked gigabyte s3-965p sounds fantastic though --
Thanks for the advice. I cant remember, but I think that Intel board can do crossfire cant it? I think I'll go with the D975XBX. Our local Fry's had a few on sale for 212.00.
Alright, I bought the intel D975 board. What a wonderful piece of work. Another question. Ive heard that this board will accept DDR2 6400 800mhz ram even though it doesnt address this in the paper work. So, I bought 2 gigs of Corsair DDR2 6400. I hope it works.....
