Need help deciding between two monitors.
Hey Friends!
I'm a new member around here and thought I might be able to ask for some input from the community about my first IPS monitor purchase. I've looked at countless different monitors but I think I've narrowed my decision down to two. The two i'm deciding between are: http://www.amazon.com/Asus-MX239H-23-Inch-LED-backlit-Frameless/dp/B00B1IAL7W and http://www.amazon.com/gp/product/B00CIZZ0QO/ref=s9_simh_gw_p147_d0_i5?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0KXA42GQ99YWQ03ZK125&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846 . I did a search on this website for the ASUS VS24AH-P on this website and it seemed to receive very favorable first impressions from some of the users that had purchased one. The one thing that is kind of bothering me is the fact that I can't definitively find out if that particular monitor is AH-IPS or not, the technical specifications on Amazon and NewEgg do not state the panel type. I probably shouldn't let that really weigh my decision, but I have read AH-IPS panels are newer technology so I figured I would try and get one with that specific panel. Asus' website also does not state the panel type but do with some other models, which leads me to think that it might not be that particular panel. So I was just wondering if anyone might be willing to help me out on this decision, any help would be greatly appreciated. I see the stands on both of them are pretty bad, but I think i'll eventually go for a VESA mount eventually ( I know it's not an option on the first monitor). Thanks so much for reading!
