Need help deciding 3D Display for my system
Well, I am going to be getting into 3D IT Compression of HD content but I need a decent size monitor to do this. The largest display that I have found is 27 inches. I am looking for at least 50 inches and rendering in Linear style 3D (my choice due to less ghosting of RealD). I have the ultimate system listed below but I need a larger Monitor or HDTV that can do Linear Rendering.
Any Help will be appreciated.
My rig:
This is my system specs
Thermaltake Xaser VI VG4000BNSB Black Aluminum ATX Full Tower Computer Case - Retail
Thermaltake Toughpower W0133RU 1200W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power ... - Retail
Intel Core i7-975 Extreme Edition Bloomfield 3.33GHz LGA 1366 130W Quad-Core Processor Model BX80601975 - Retail
ZALMAN CNPS9900ALED 120mm 2 Ball Low-noise Blue LED CPU Cooler - Retail
EVGA 170-BL-E762-A1 LGA 1366 Intel X58 4-WAY SLI Classified XL ATX Intel Motherboard - Retail
CORSAIR DOMINATOR 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMD12GX3M6A1600C8 - Retail
2 XFX HD-587A-ZND9 Radeon HD 5870 (Cypress XT) 1GB XXX Edition 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported ... - Retail
2 Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
2 Western Digital RE3 WD1002FBYS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - Running Raid 0
Pioneer Black Blu-ray Disc/DVD/CD Writer SATA Model BDR-205BKS - OEM
SAMSUNG P2570HD Black 24.6" 4ms HDMI Widescreen LCD Monitor - Retail
Microsoft Windows 7 Ultimate Full - Retail
I know that I should have waited for Nvidia Fermi Line of Graphics for the CUDA.
peace
super
Ok you need to define your terms. I don't know what Linear Rendering is and what you want in terms of a 3D display. All the ones I'm aware of are the shutter glass technology, so if that's not what you are after you are probably screwed.
If you want an HDTV that does shutter glasses 3D, well just go get one. Crutchfield sells lots. Pick the one that is right for you. If you want a monitor that can handle higher resolutions, like 4k, you probably have to get a projector. I am aware of 4k LCDs and 3D LCDs but no 4k 3D LCDs.
...but I need a decent size monitor to do this. The largest display that I have found is 27 inches.
... I am looking for at least 50 inches and rendering...
Why? explain your workflow and environment. Is linear rendering a term related to texture gamma correction? I'm still reading.
