dcschess05
- Sep 30, 2007
Hey all! I am looking to purchase a 32-40 inch LCD TV with a native res of 1080p to use as monitor for my new computer. I will be using it to do everything, mostly PC gaming though. (I'll be sitting 2-3 feet away) Id like it to include a HDTV tuner and maybe another input for an XBOX360. The only monitor that has caught my eye so far is the
http://www.newegg.com/Product/Product.aspx?Item=N82E16889234025
Westinghouse 37" LVM-37W3SE
Is this a good/bad choice? I have read that beastly thread and it seems like the SE's have been giving people problems, should I skip this display?
One problem I face is I live in Alaska, so shipping up here is either not an option for online vendors or they charge an insane amount. Would I be better off going to a B&M to make my purchase? What B&M retailers can I trust to sell me a quality display that you guys might recommend?
Final question! If you were in my situation, and had up to $1500 at your disposal, what display would you go with? Please be specific, thanks for your help!
