Need Help Connecting XBOX360 via VGA
Blinkme323
Hi, I have a Zenith 47 Presentation series TV with model number H3647DT. It has these specs:
36" 4:3
1024:768 Native res
800x600 SVGA front input
1600x1200 VGA back input
560 scan lines progressive
I play my Xbox360 on it and it doesn't have component inputs since it is a few years old. These Tv's are used in schools because you can use computers on them through the VGA port, so I bought the VGA cable for my Xbox.
I never used the VGA before, but it supposedly has great quality. I connected the VGA cable to the rear port first and switched to that TV source. I got a weird pixelated green/blue screen. You couldn't make anything out, but the sound worked. Then, I tried the front and switched to that TV source. It was just black with a few lines on it.
For troubleshooting, I tried hooking it up to my Dad's 17" LCD. It worked perfectly with all the dashboard options. Can anybody help me out?
Im guessing its because the 360 VGA cable doesnt support the resolutions you listed for the front and back vga inputs on the TV.
My rear vga supposedly supports any resolution up to 1600x1200 at any refresh rate up to 100hz. I tried 3 resolutions and it didn't work. Can't do anything else now since guests are coming soon.
