HI
I am trying to support a small business. They have 2 PC's connected to a high speed connection. 1 PC works great.
The other one will not connect to the internet. It will ping the server IP and respond good. Router works with my laptop and the Cat 5 cable to #2. (cable OK). (router OK) Using PC's are XP pro. I removed all network settings and reset them. Did a repair using original disks. Ran SP 3 and all updates. Tried a new NIC and no internet.
Still no internet. About 6 months ago, the PC had the same problem and reloaded as a clean install.
Can anyone tell what to check and how to cure this problem without another clean install.
I have searched Microsoft and several forums with no help.
Thanks
Henry
Thanks
Henry
