Need help configuring first sff
lilming
Hi, Ive been looking around and decided to build a sff. I was first looking into getting a shuttle but they seem exspenve so i think im going to go with the silverstone sg01. My main goal is basicaly to create a small gaming machine. I dont plan to oc or anyhting, stock is fine withe me. Also noise does not matter. i usually have music on anyway. I’m here to ask you guys to make sure everything i plan on buying is compatable and fine.
First the sg01. I think this is the neweset evolution one?
http://www.newegg.com/Product/Product.asp?Item=N82E16811163050
PSU- Seasonic 500w Im thinking this will fit, wires do look a bit in the way tho.
http://www.newegg.com/Product/Product.asp?item=N82E16817151024
MoBo- Foxconn G9657MA Watever model doesnt matter, but newegg doesnt seem to have this nor anywere else except ewizb
http://www.ewiz.com/detail.php?name=MB-9657MA
CPU-e6300 nothing special here, should be compatable with the mobo
http://www.newegg.com/product/Product.asp?item=N82E16819115005
Ram- G.SKILL 2GB DDR2 800 ok this is where i need a lot of help. is this ram compatable? i read somewhere that the mobo only boots on 1.8v. this particular set of ram is at 1.8V-2.0V according to the website. Will this work??
http://www.chiefvalue.com/Product/ProductDetails.aspx?Item=20-231-098
GPU- 8800gts. only concern here is if it will fit but looking aorund it seems like it does.
http://www.chiefvalue.com/Product/ProductDetails.aspx?Item=14-130-071
I think thats it, anything i didnt mention like hd, monitor i already have and should have no problem.
I just need to make sure those item above fit and work with each other.
But after digging more and more everything seems to be fine except the ram. I have no idea if this one works
Thanks a lot!! Cant wait to build this.
