I've try to config the wireless conecction on my 851w
but it didn't work -
can you please give the set of command to get the wireless on my router working
Current configuration : 2108 bytes
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Neo
boot-start-marker
boot-end-marker
enable secret 5 y2HgKnerP3TlCYfS1
no aaa new-model
resource policy
clock timezone GMT 2
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.115.106.35 62.219.186.7
ip cef
ip name-server 192.115.106.35
ip name-server 62.219.186.7
username isaac privilege 15 password xxxxxxx
interface FastEthernet0
duplex full
speed 100
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description ADSL CONNECTION
no ip address
ip virtual-reassembly
speed 100
full-duplex
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
no dot11 extension aironet
interface Vlan1
ip address 192.168.1.1 255.255.255.0
ip nat inside
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username xxxxxxx@014 password 0 xxxxxxxx
ppp ipcp dns 192.115.106.35 62.219.186.7
ppp ipcp address accept
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip list 1
control-plane
alias exec s show ip int bri
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 30 0
logging synchronous
login local
scheduler max-task-time 5000
end
