Need Help. Computer won't get past bios boot screen.
jucestain
Here are the specs:
E6600
Gigabyte DS3
2GB Crucial Ballistix
Corsair 620HX
8800GTS
160GB WD 7200RPM
The computer was fine earlier today, but when I turned it on at around 5, it wouldn't get past the bios boot screen. If I click delete, it will enter the menu for the bios options, but it takes a couple minutes for it to do so. I switched the hard drive for another one, and it did the same exact thing. So, I'm thinking the problem might be with the cpu. I did some overclocking, but it wasn't very extensive. The vcore was 1.45 and it was overclocked to 3.4ghz. After this happened, I decided to set the settings in the bios back to the default, but the same thing still happens. Anyone have any ideas? Thanks,
-juce
