Need help chosing a CPU for Carputer
bosstone74
I'm getting this for a motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500012
This for memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148160
My choices for CPU's looking for low heat (I'm NOT overclocking) and low power consumption. But I think they are all 65W.
Intel Pentium E2180 Allendale 2.0GHz LGA 775 65W Dual-Core Processor Model BX80557E2180 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116052
Intel Pentium E5200 Wolfdale 2.5GHz LGA 775 65W Dual-Core Processor Model BX80571E5200 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
Intel Pentium E2200 Allendale 2.2GHz LGA 775 65W Dual-Core Processor Model BX80557E2200 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116063
Intel Pentium E5300 2.6GHz LGA 775 65W Dual-Core Processor Model BX80571E5300 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116074
Intel Pentium E6300 Wolfdale 2.8GHz LGA 775 65W Dual-Core Processor Model BX80571E6300 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116091
Intel Pentium Dual-Core E5400 Wolfdale 2.7GHz LGA 775 65W Dual-Core Processor Model BX80571E5400 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116076
Intel Core 2 Duo E7400 Wolfdale 2.8GHz LGA 775 65W Dual-Core Processor Model BX80571E7400 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115206
Let me know what you think?
Well what are you doing with the carputer? The GeForce 7100 isn't powerful enough to decode HD video so it that is what you are planning to do you will need a fast CPU.
E5200. I r passively cooling my entire WHS with just 1 Noctua 900rpm exhaust.. in a closet.
E5200 no doubt. No sense get the E2180 or E2200 when the price is the same or almost the same cost. No sense pay extra also for an E5300 or E6300 when the E5200 will have no problems meeting your requirements.
