I have a 500R case and I am debating between these two coolers to cool my FX8120. The main concern is, I do not want to take out my motherboard, ever, because my CPU power cord was a huge PITA to run, and I never want to go through that ordeal again.
I like the Noctua because I am used to using air cooling, and it should be the quieter solution. However, I am also uneasy hanging such a heavy object on my motherboard.
I like the H100 because my case was designed to work with that, and I have enough fans for a push pull configuration, but I don't know if I can install it without pulling the motherboard.
If anyone has experience with these coolers, I would appreciate your insight. I am also open to recommendations on other coolers, but it needs to be sold by Amazon, as I am using accumulated Amazon points to buy it. Thanks for the help!
