Need help choosing between C7180 and MP610
Phrozt
Or.. if you could recommend a better one.
Trying to choose a MFC printer. Photo printing is important to me, but I'll also be using this for scanning and your general mapquesting quite a bit, if not more than photo printing.
There doesn't seem to be an incredible amount of up to date reviews on the latest printers, nor very active printer forums (other than this one), but from what I can tell, two very good ones would be:
HP Photosmart C7180 All-In-One Print Fax Scan Copy
http://www.newegg.com/Product/Product.aspx?Item=N82E16828104516R
and
Canon PIXMA MP610 InkJet Photo All-In-One Color Printer
http://www.newegg.com/Product/Product.aspx?Item=N82E16828102254
Which of these would be better? Should I be looking at something different?
thanks!
Don't know if you've made up your mind but I thought I'd chime in. I just purchased the MP610 from Amazon for $149.99 several days ago. In fact, I haven't even unpacked it as it's sitting in my office now.
I bought it because I was looking for an MP600 and apparently this is essentially the same unit, just a newer model. I bought my mother the MP600 last year for X-Mas and was completely blown away. Pictures were fantastic and she does A LOT of printing with the new addition to the family....I just replaced about half of her ink tanks this past weekend. I couldn't believe how long the ink lasted. I threw my Epson out the door. I say MP610.
Long lasting ink? That sounds nice...
Have either of you had a chance to compare it to the HP line?
Thanks for your replies
I compared the MP600 to several HP models last year before I bought the MP600 for my mother. They were all setup at BestBuy. I just felt the Canon unit was a much better piece and I'm glad I bought it. As for the MP610 vs newer HP units, I have no idea. I went straight for the MP610.
The MP610 is my first Canon printer and I hooked it up last night. Works great. I used to have 2 x HP's, then 1 Espon (which I regret), and now I'm with Canon. I've also read that you can replace the print head on your own with the MP610 and....you can buy a cd tray to print directly onto cd's with the unit. Apparently it's available on the European unit but disabled on the US version. I heard it works though.
