Need help choosing a power supply
ebs5049
Title says it all. After a long hiatus, finally rebuilding my computer.
I'm going to have a Gigabyte Z77X UD3H board with an i5 3570k, 16gb of DDR3 1600 ram, and a GTX 670. Also, I will have a SSD and 3 standard drives.
I used a power supply calculator for my requirements and it showed ~380 watts. Seems pretty low.
I know I want a modular supply, and was leaning towards the Corsair HX750, unless somebody knows a better value. I currently have an Antec Earthwatts 650W right now. Would that suffice? It isn't modular but I could always get that component last if it is good enough.
I don't plan on OCing. SLI is a possibility.
Thanks
Thanks
The EA 650 would also be (comfortably) enough for SLI 670s, you'll need PCIe adapters though (the EA 650 is a value/lower mainstream product with rather limiting connectivity for its output).
HX750.
Thats what I would pick. You'll give yourself more head room for anything else you wish to add later on and you can also overclock if you wish to and not worry about anything. You'll be basically buying a unit that you can use later in other units, and not have to worry either.
