Need help choosing a new mobo!
91ZX
Systems parts
Im a little shaky on choosing a mobo any help is appreciated. Id like to get an sli compatible board just in case for the future but if the price is a big difference I dont need it. Opinions are welcome. I was looking for something in the 70-100$ range. One thing that was bothering the ram I chose has a speed of 6400 but didnt see any mobo's supporting, just stated it supported ddr2 800. Does that mean it supports all ddr2 800 ram? thx in advance.
well there are the nf-5 series mb's some of them are inexpensive like the ecs for about $70. i don't think it's much of a overclocking mb. i also think its a 8x-8x pci-e. not a 16x-16x pci-e.
as far as the 667 ddr goes--most 667 will overclock to 800mhz with just a little boost on the v-dimm. it should be ok for a mild overclock.
the best mb's for the core 2 that run from $99-$150 are the 965p series from gigabyte and asus. although i've heard that the biostar and the foxconn are also very good .
the foxconn 965p-aa dosn't have cpu multi adjustments . although the lack of adjustments won't be much of a problem with a 6300 or 6400 core 2.
if you have to have 2 pci-e's and don't want to spend $200+ you might consider the dfi 975x-g
or the MSI-975x or maybe even the foxconn 975x-ab . they run from $160-$170's -=-the DFI is a good overclocker with the new bios . before getting a 975x though i would read up on them first as they have some "needs " --like the DFI likes on psu but hates another--even though the psu has enough amps. the MSI seems to like some ram but not others ect--. the foxconn could be a solid mb--but it don't overclock much --it's a under 400mhz mb. the 975x-g mb do have one big advantage though--they can run sli or crossfire--something even the famed evga 680i and asus striker can't do.
i still find the one videocard and overclocked cpu the be the best overall-- i would get a gigabyte-ds-3 some good ram and overclock the cpu to 450+fsb. but that's just me--lol
