I am using the system in my sig. My old case was very loud so i decided to buy a new Antec SLK3700-BQE case. I've noticed that over the past month my cpus temperature has been steadily rising. I used to get 50C at full load and 42-45C at idle, now i get 54-55C at idle to light load and 59-60C at full load. This trend started in my old case and has continued to the new one. I am using a thermalright slk-947u heatsink and the stock amd fan (i never had time to buy a new fan before and the fan was keeping my cpu relatively cool before so i didnt think too much of it). my cpu is overclocked to 3200+ speeds. even when it is not overclocked, i still get the same temps. The only fan i have in there besides the cpu fan is the stock 120mm fan that came with the case. I decided that it was time to replace the stock amd fan and get a new one. Anyway i saw a few fans that looked like they were decent.
Thermaltake Smart Blue LED Fan Series A2017
http://www.thermaltake.com/dcfans/smartFanmenu.htm
Thermaltake Silent Cat 9CM A2013
http://www.thermaltake.com/dcfans/ComboCool/a2013silentCat9/SilentCat9.htm
Panaflo 92mm L1B
http://www.jab-tech.com/customer/product.php?productid=2608&cat=80&page=1
Silenx 92mm x 25mm 14dBA iXtrema Fan
http://www.silenxusa.com/productcart/pc/configureprd_z.asp?idcategory=9&idproduct=37
Has anyone ever used one of these fans? Do you have any recommendations? I want the fan to be quiet but will cool my cpu decently. Thanks for your help.
Panaflo 92mm L1B
