Need help choosing a new case
IsaacMM
Hey, i need a new case for my rig and i decided i would get a Lian Li full tower. I'm going to run it on air, already bought a TRUE, what case do you think is the best for that? Price doesn't matter i just need the best one at air cooling.
Thanks!
Although the P80 is a great air cooled case it is very expensive. If ur looking for a LL full tower i would reccomend the PC-V2000 PLUSII or the PC-71. To maximize the air flow you should clear out all stock built in grills and replace with less restrictive ones, and cut a 120mm blow hole or two in the top of the case. This should give you all the air cooling you will ever need.
Also if you decide to go with the V2000 keep positive pressure on the interior of the case (more CFM in than out) to keep dust at a minimum because that case has all those holes in the front face plate.
The PC-A70 is nice, My temps dont go above 28 idle on air.
Also the new PC-V2010 doesnt have the mesh front like the V2000 does.
