clownshoes
- Nov 10, 2012
Hey, I'm finishing up my current build and need some help choosing a motherboard. I'll be using a 2700k. I think I've narrowed it down to the asus p8z77-v and the asus p8z68-v gen3. Both boards are the same price. Normally I'd go with the z77 being the newer chipset and all. My problem is that the z77 only has 8 power phases for the CPU where as the z68 has 12 phases. It seems anything over 12 phases is usually considered overkill and just a marketing tactic. The difference between 12 and 8 isn't as clear though. Additionally, the quality of the phases seems to play a large roll. I like to go for low voltage overclocks. Keeping this information in mind, what motherboard would you go for? Any information is appreciated.
Thanks
Thanks
