Need help choosing a case with 4870X2
Unhooked
Hey guys,
I need some help choosing a case that''ll house a 4870X2
Choices so far are SG02-F, SG04, Lanbox lite or Lian Li V350. I plan on using the Silverstone NT06 for cooling
My main concerns are temperatures since the 4870 X2 gets really hot.
Please advise thank you
Doubt the v350 can support the X2.
SG02 yes, dunno about 04.
Lanbox Lite will require cutting external 3.5" bracket and removing HD cage.
All of them provide enough cooling for the X2. Yea it gets hot in anything, whatever. Adjust the fan.
V350 is little wider than the SG02....most likely I will go with the SG02 since its less wide and the NT06 with a reverse mounted fan work out just fine..
