toekneedahtiger
- Aug 15, 2004
Hi, I'm new to the whole ATI thing after using a 64MB Geforce2 for so long. Recently I've been thinking of picking up a 128MB 9800 pro but I can't decide which brand to go with. The choices are Sapphire (OEM $189.99) or MSI (RETAIL $209). I've noticed the heatsink difference on the MSI and I was just wondering if that is enough to justify the $20 difference. I don't plan on doing much overclocking, since I'm afraid of throwing a $200 investment down the drain. So in your opinion, which is the better card for the money out of the box (or packaging)? I'm not exactly sure what cores they are running, but is it something I should factor into my decision making?
Also, will this be enough to run HL2 and CS:S smoothly? And by smoothly I mean will the fps stay high and constant? Thanks in advance.
My specs are:
ASUS A7V8X-MX
AMD Athlon XP 2800+
1 Gig of DDR-400 RAM (Yes, I know I only need 333)
Enermax 350W PSU
My specs are:
ASUS A7V8X-MX
AMD Athlon XP 2800+
Enermax 350W PSU
