This just started happenning today, I cold booted my computer this morning, everything loads like normal, but when i try to run firefox nothing happens. I suspected I tried to run it too soon before the system loaded all the startup processes, but after I restart, windows did a CHKDISK. Then reboot, everything worked fine. I came back this evening, samething happened again, except this time, firefox said it can't find some file . . . The rebooted, CHKDISK started again. After CHKDISK rebooted once more, everything seemed fine, and firefox loads up normally.
What could be causing this problem? Could be virus? I am most concerned with whether this foreshadows a hard disk failure, because I have a lot of data that I can't afford to loose. Any help will be appreciated, thanks.
