Hey guys,
I need help calculating how much bandwidth is being used by 25 Slingboxes on a network. The Slingbox website says it needs 3Mbps or higher for HD streaming so I want to use that as a base point.
The second part of this is: Will this kill the network?
The Slingboxes are connected to a Cisco switch (I am not sure of the model) but each port is a Gigabit link.
I realize the Slingbox can auto-sense network traffic and adjust it's picture quality and bandwidth usage but I need a base point to start from.
Thanks in advance.
Edit-
If I do this calculation via a method I saw at one website:
If your network is GbE, that would give you 125,000,000 bps. This is computed by taking the 1000 Mbps (for a Gigabit network); which is 1 billion (1,000,000,000) bps and dividing it by 8 to come up with the bytes.
(1,000,000,000 bps / 8 = 125,000,000 Bps)
Then 125,000,000/393 216 bytes per second (for slingbox)
I get 317.8 which would be the number of Slingboxes able to be on the network.
Yet if I use this website http://web.forret.com/tools/bandwidth.asp?speed=3&unit=Mbps
Then a 3Mbps device will use almost the entire 1gig pipe.
I'm confused.
Thanks in advance.
Edit-
I'm confused.
