Need Help Building First WC System -- For SR-2
Jacez44
I am building my first WC system, on the SR-2.
I am cooling two Quad/Hexa cores and 3 GTX 480's, all OC'd as far as possible.
This is my first draft (I've been researching for hours):
Pump: Iwaki RD-30 / Dual-MCP355
CPU Block: EK Supreme HF
GPU Blocks: ???
Radiator: Feser Limited Edition "Monsta Lite" / Black Ice GTX Gen Two Xtreme 560 (both dual)
Reservoir: ???
Tubing: Feser UV 1/2" ID 3/4" OD
Fluids: ???
Fittings: ???
Okay, that's my idea so far. I need someone to plug the holes and/or change what I already have.
Thanks Guys.
GPU block: get Koolance or Danger Den block
Reservoir: for limited space Swiftech Micro-Res
or the Frozencpu T-Virus reservoir for larger space
Fluids: distill water + pt nuke/silver coil
Fitting: compression fitting (for the look) or go cheap with barbs + clamps
Dude, I bought a Swiftech kit about 3 weeks ago and only ended up using a few of the parts in it. If you want I could hook you up with it.
Okay, what about what I already have?
Anyone else agree with this?
I want more input.
I may in a few months be doing the same thing, but I'll be dropping into my sig rig which is already setup w/3 x 120 RADs.
Highly suggest the Koolance GPU WBs. I've got 3 for my GTX285's and they were cheaper and work just as well as the other brands.
If you go with the 355's, get the aftermarket tops. Definite improvement over stock.
Fittings is personal preference. I went with BP Compression and they look great. They are EXPENSIVE as all get out once you figure out all the parts you need.
My current sig rig uses a SwifTech (can't remember the model number), but will likely be switching to HeatKillers as part of the upgrade.
