First thing first, here is the system spec:
P4 3.0E (SL79L) - WC
Gigabyte GA 8i875 Ultra
OCZ EL DDR PC-3200 Dual Channel Platinum Rev 2 (2x512MB, TCCD)
600W Power supply
This is the first time I'm trying to overclock since my old, and now dead 4 years ago, K-2 350@550 (the poor thing lasted 2 years!
). I know my MB may not be an overclock killer, but I'm sure I can get a lot better than this. Here is the numbers I get:
@ 220MHz
2-2-2-5
vDimm: 2.6V
vCore: stock (1.3875, but MBM report 1.47 and GB utility report 1.49)
vAGP: 1.5V
@ 225+MHz
Post, but memtest errors everytime
Tried:
vDimm 2.7V, 2.8V and 2.9V
2-2-2-5, 2.5-3-3-6, 2.5-3-3-7
vCore: up to 1.5250V (1.5250V is reported as 1.59V with MBM)
vAGP 1.6V and 1.7V
You can combine all this together, nothing work. memtest fail in test #3 first pass everytime. Since I'm able to run this thing @ 220MHz 2-2-2-5 2.6V rock solid, there must be something to do with it to go higher?
600W Power supply
@ 220MHz
2-2-2-5
vDimm: 2.6V
vAGP: 1.5V
@ 225+MHz
Tried:
vAGP 1.6V and 1.7V
