Need help at purchasing a computers!
gb4790
:confused:
I am planning to buy a gaming computer next few weeks at puget or digitalstorm, but i dont' know which one of company should I choose. Since digitalstorm is more cheaper than puget. Please help me choose or add any other comments. And I have another question, if i choose nVidia 8800GTX 768MB for my video card, at least how many watt power supply should i get for it?:eek:
:confused:
a quality 600w PSU should be enough no problem :)
Puget is a good maker, also take a look at velocity micro, overdrivePC, and maingear if you're still looking for options :) all 4 are great :)
I'm not all that impressed with DigitalStorm's customer ratings.Puget seems well rated,but a bit overpriced.If you're looking for great customer ratings and prices,check out AVAdirect,too.
Yep :) look into AVAdirect, seems to be an amazing company!
If you're looking for a great computer at a low price, check out AVA Direct. Velocity Micro and Maingear are also great companies, but will probably be more expensive. I'd suggest configuring what you want at each company's web site. Puget, which you've already looked at, will also probably be more expensive than AVA Direct. Digital Storm hasn't made it into the top 5 companies that people here at [H] use.
AVA Direct has a LOT of choices in components, so be sure to ask here if you have questions about which will be best for your needs.
Gary
For me VelocityMicro is first class in my books. Not only are they English speaking from that far off place in Virginia, they really do come through when you need them. Each question I have asked has been answered, and a couple of glitches, one that I caused, was handle by the top team.
I had a Dell for 5 years, and they do not come close to VM, and if you need some hand holding, they will do it. No one is perfect, but they are very close.
VelocityMicro Gamers Edge PCX
eVGA 680i SLI ChipSet
4 Gigs Corsair DDR2-8500 1066 mhz 5-5-5-18 2T
Arctic Freezer Pro 7
Vista 64 bit Premium ( OEM )
8800 GTX single card
E6600 cpu
250 WD 16 mb cache HD
