NEED HELP! Asap....
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=3&model=281
I am using the Abit AL8 for a project and trying to update using the latest BIOS. I however have no floppy drive, and the boot CDs I am making are failing.... I need to know how to make a BOOT CD ro update the BIOS with POWERISO.
Also, when I am doing something on the PC, like trying to update, the computer randomly dies. Is it because of heat? I have the stock intel heatsink (for a C2D Q6600) on a Pentium D 3.0ghz...I don't know what version my board is either. The temps are a little high it seems, but 20*C under the shutdown when I go into BIOS...but it will still shutoff even in BIOS....when I boot without a CD rom, it says the processor has changed, which I think means it needs a new BIOS because even when I clear the CMOS this happens, but it may be too hot too....if so, I can pull my ARTIC COOLER FREEZER 7 PRO out of this PC and use it for the night or a hour or so....Or is it not getting enough power? The PSU is a 480W Rosewill powering sata hdd, sata dvd+_rw, board, 2 fans....
Thanks for reading this jumbled mess and any help is appreciated.
I suggest try testing components one at a time. Unplug everything except for 24pin psu, 4pin psu, cdrom, and your video card if you have one.
Double check you have mounted the HSF properly and reapply some thermal paste. The Q6600 HSF should be fine for a toasty Pentium D. P-D's run really hot so don't be alarmed at high temperatures.
Boot into bios and set to defaults on the bottom right menu. Save and exit. Go back in and ensure your memory and CPU voltages are at stock in the bios by using the health monitor. Also check that your PSU rails arent drooping (example: 12V should read close to 12V)
Now go to http://www.memtest86.com
Burn an ISO to CD and boot off that. If you can make it all the way through 12 tests your ram is probably okay. If you are getting memory errors, you know it's your ram and you can swap sticks or increase voltage.
Post back with your results
I went and loaded optimized defaults, it restarted, I pressed tab to see post and it shutoff...I don't even think it would let me book far enough in to get to the memtest.
Oh and BTW, the heatsink (any stock Intel one I use) is not clipping down all the way. Like 2 of the clips will, and it will seem steady, but it is probably not.....I think I just should get a new one.
Just checked...no thermal grease :crash:
I am gonna just go check out TigerDirect tomorrow for everything.
