Need help asap!
you can directly connect the 8pin on the 4pin, if nothing is blocking the extra 4pins hanging over the end(if the mobo is fairly new, you will not have problems with this). check your mobo manual, it will say at some point which part of the 8pin psu connector you have to connect to the 4pin mobo connector.
That isn't possible on my board unfortunately :(
Please, somebody must have a solution
well, got it figured out, the 8 pin splits into a normal 4 pin, it just doesn't say anything in the manual, thanks thermaltake....
