Need help ASAP This is a tricky one!(plz)
incomudro
Please any insight at all is greatly apreciated!
Problem =
: 6800GT (AGP) Windows doesn't recognize anything about BIOS info ect....doesn't even see it as a 6800GT w/ or w/o drivers installed
The plot thinkens Months ago the card was soft volt modded to 1.4v BIOS from a backup of the original.So i thought maybe the BIOS got screwy some how (the card wasent in use for 4-5 months (i was thinking maybe the battery died??) so i tried flashing it with a new one from white rabbit.com or something....Now the card gets to the windows xp loading screen where the bar goes on the bottom and then it goes like its going to load up the welcome screen and then goes blank.And then 30sec later you can see "......." at the top of the screen but thats it.I know windows loaded and there is not display b/c if i wait 1-2min and then press the power button it powers down by itself. I tested it after this with a ATi card it goes right into windows and can be identified by windows ect. no prob.
Info that might help
Asus A8V
winnie 3000+
1gb memory
eVGA 6800gt w/ NVS5
80gb sata hdd
windows xphome edit sp2
520w silverstone psu
Please i need help this is for my little bros new system that i am giving him for a graduation present
Based on your description, it sounds like the 6800GT is somehow malfunctioning; given that your verified proper system operation with another card. Since you also admit that the 6800GT BIOS was modified, perhaps you need to find a method that will rewrite the BIOS in question in an attempt to revive it. The card could have also been damaged from static or some other injury during the 4-5 month inactive period.
Good luck
id say get a PCI card and re-flash the BIOS back to the stock one see if that fixes it if not its DEAD
yeah i fearded it might be dead i have tried multiple bios
only thing i have left to do is try it in an other computer
