BioInclined
- May 23, 2011
Ok, try to keep it short and to the point.
My system info is below. I am not OCed. Today I did DL AMD OverDrive to consider bumping my system a bit, maybe to 3.4GHz max. I ran the novice level one test, then the auto clock, it seemed to have taken me to 3.3GHz. I ended up "un-OCing" it, setting it back to default clocks and let it be.
Then the issue, maybe 1 hour or so later(when i noticed), my little windows 7 gadget was only showing 800MHz for my clock and not moving.
Upon inspection, i found my new AMD/ATI Overdrive(don't know whats so great about naming these things that) driver which was a ATI set up one for the card, has a settign for my processor to determine what load i want it to max out on, it seemed to be in or out of game option. It was set to 800MHz max. So i reset it to 800MHz-3200MHz.
I then noticed my temps are up as well. Not but 1-2 days ago i was idling at 34-36*C, web browsing and watching HuluHD vids at 37-39*C and gaming(Left 4 Dead 2) at 41-43*C.
Today i am idling at 48-50*C, Web/HuluHD at 51-53*C and L4D2 at 53*-57*C
I looked into it and found a lot on Cool n' Quiet, so i disabled it, didn't seem to do anything but I did notice regulation of my Clocking based on load i needed to application.
It about an hour ago just bailed out and i saw a message flash for about 1 sec, most i caught was "Processor unit can not function properly shuttign down" or along those lines. Prior i saw no temp spike or Core use spikes. I was literally watching PArks and Recreation and CPU-Z then it happened.
At some points in L4D2, i was hitting high temp and 89% CPU use...that seemed uncommon to me.
I am not incompetent when it comes to thing like this, i have patience, so i began to search the forums here and elsewhere. I could come up with solutions but none fit my case.
I tried to check for a BIOS update but to no avail(through software from Gigabyte) then on the site. Should i go from my current F5 BIOS to F12(flashing it)?
Moments before posting this i restored my system to about a week ago, i know it won't do the BIOS, i just wanted to to clear my head and get rid of the new ATI software so it removed the "OCing" of my processor option.
Any ideas on where to go from here?
Side note: The idle temps have been on the good side even in an 80*F room. I had the AC on all day and at 72*F, then had a fan blowing too the PC and still can get below 47*C in good moments.
Attached is pics from CPU-Z from 11:33pm Central(Chicago) Time.
Does this seem to look right? I know the voltage looks fine(1.35v)
http://imageshack.us/photo/my-images/577/help1c.jpg/
EDIT: CPU cooler is aftermarket, not much better, copper piping and is a bit bigger than stock. I'm all air, rear 120mm, front 90mm. I have one of those duct/tube things to help direct air from the side of the case in tot he CPU, thats the area the fan was kind of aimed towards.
